Ring Map help plz
Is there a way to change the rotation of the Ring map under the mapper tab. So the rotation is clockwise as opposed to counterclockwise.
Thank you,
Twilight
Just change the sign, I think:
c = i / pixelCount * Math.PI * 2
becomes
c = i / pixelCount * Math.PI * -2
If you asked “when I am ever gonna use this?” in math class … now you know.
Thank you! I know in some of the patterns changing the time value to a negative number can sometimes change the direction of the animation, but I wasn’t sure if that applied to the map also.
Twilight
