Was curious to try a “static” pixel based image. My kid’s school is running the Wizard of Oz this year, hence the Dorothy graphic.
Used sheets to easily map out my 20 x 50 grid, then copied the index numbers to Sublime, and used Sublimes text manipulation to convert to drop in “if index == x” statements.
Did you paste the big || condition list into the main render, or did you build a cached array once and index into it? I wonder if that’s a meaningful performance boost (though for a static image, maybe we don’t care).
// Build an array of hues and brightness values
hues = array(pixelCount)
values = array(pixelCount)
for (i = 0, i < pixelCount, i++) {
if (i == 240 || i == {big manual list of blue indices}) {
values[i] = 1
hues[i] = 0.66 // or whatever color you're painting
hsv(hues[index], 1, values[index])
Oh, that’s cool - didn’t realize you could do this approach. I was looking to see if “includes()” existed in the js subset - and when I realized it wasn’t I just stuck them in brute style. Thanks for the tip!
Could probably take it a step further and write an apps script in Google Sheets to grab the index and background color and create the array from that. For another day…
Here’s another set of tricks you can leverage using array literals. You can use variables in array literals, so you could do something like this, creating a memory efficient nested array:
cBlue = [.666, 1, 1] //in HSV color space, but you could use RGB as well
cRed = [0, 1, 1]
// etc...
pixels = [cRed, cRed, cBlue, cBlue, etc...]
var color = pixels[index];
hsv(color[0], color[1], color[2])
