Are sliders always between 0 and 1? Is there a way to specify the min and max?
The slider itself controls a local variable (usually v, but it could be anything), that goes from 0 to 1.
What you do with it to your own variables, that’s on you. So if you wanted to do a min/max, you use the 0…1 range of v, and adjust your own variables value within the range of min/max
MyVariableName = (Max-Min)*v + Min
(look familiar yet?)
The power of repetition, in my learning, is great! (To the question if I recognize the equation yet)
The only downside to this is that the slider labels that you see as you use the slider will still remain 0…1 Your solution is elegant and I feel like I have seen that equation somewhere else…
Ooh, that’s a Useful UI change, @wizard :
Slider labels? So you could add a label to either side of the slider, and hide the 0…1?
“less” “more”
“Reverse” “forward”
“Slow” “fast”
Etc…
Actually I think I’ve said it before but a “switch” (slider with no middle, just 0 or 1) would be useful too. Same UI or a real switch)
What labels? Can you send a screenshot and browser info?
Was wondering about that – no labels here on firefox, firefox focus or chrome.
