I’m experimenting with some non-animated patterns and even simple single color patterns.
I notice with some of these I will get a “shimmering” effect across the strip, or also some unexpected colors or changes in color across the LEDs.
For example, an all white pattern at 100% is only showing red.
export function render(index) { hsv(0, 0, 1) }
A blue/green pattern shows blue/green for the first 25 or so pixels and then just green after that.
export function render(index) { hsv(.55, 1, 1) }
White turned down considerably is doing the shimmering thing, and is mostly orange.
export function render(index) { hsv(0, 0, .5) }
White turned down very far is clean.
export function render(index) { hsv(0, 0, 0.08) }
I’m running a new PixelBlaze with updated firmware. LED strip is a WS2812B. Docs say it can pull 30W, so that’s 6A. My current power supply is 5A, so it’s a little under powered. The PixelBlase is powered together with the strip.
I’m guessing that I’m simply overloading the capabilities of the power supply. But I wanted to check if anything strange might happen on the PixelBlaze side also. Like would it be trying to continually re-render with a static pattern like this, causing the shimmering? Or if my strip is pulling too much current with the brighter patterns, am I potentially underpowering the PixelBlaze and making it unhappy?
Thanks!
