Sunrise Alarm Clock Pattern
Sunrise Alarm Clock.epe (13.7 KB)
I had a lot of fun writing this pattern to play a little sunrise and sunset and then show something for the rest of the day. Some of it’s probably generally useful as well:
Pattern starts by playing a demo
Because the pattern itself depends on the time of day, and the example isn’t very illustrative of the appearance or effect, I set the pattern to play a quick demo to record the ~10s that gets shown as the preview. This was also useful for testing.
Sunrise
Track milliseconds for smoother operation
One barrier to driving a pattern purely based on the time of day is we only get time functions with resolution down to 1 second, which creates a very slow frame rate. If we’re tracking hours, the 16 bits after the decimal leaves room for 50ms increments. I count milliseconds and syncronize to observations of second rollovers, and then construct a time of day with as much resolution as I can store in hours.
// Getter for ms analagous to clockSecond()
function clockMs() {
  return _ms
  var _ms
  var _lastSecond
  // Update ms based on delta and observations of clockSecond rollover events
  // Called by beforeRender
  function updateMS(delta){
    if (_lastSecond == clockSecond()){
      _ms+=delta
      _lastSecond = clockSecond()
      _ms = min(delta,_ms%1000)
I think I can get better resolution in time of day by tracking time of day in minutes (seconds would overflow)
I’ve posted some updates to the source on GitHub: Sunrise Alarm Clock
Sunrise Alarm Clock 1.3.epe (17.2 KB)
I just pushed a new version:
  • 3 step sunrise to play a bit more with pinks and oranges.
  • Sunsets simply reversed sun-rises to make everything a bit easier to track.
  • Configurable time spent performing sunrises
  • Better preview rendering (to help debug)
  • Set wake and sleep times with hours and minutes
  • Clouds and sky far from low sun darkened
  • Low sun changes colors
I just realized I can use
export function inputNumber(v){
and
export function inputNumber_(v){
Because the underscore isn’t printed but is part of the name, I can get multiple controls with the same text to set minutes and pairs of colors…
Yay!
