Swift Playgrounds - Pixelblaze
Hello:
I am looking to develop a version of the PB web interface as a Swift Playgrounds app. A version without the 2D / 3D mapping. I would like advise on the best way to approach this challenge. For example, would using the Pixelblaze-Client created by zranger1 be a starting place for identifying the fundamental components necessary to recreate basic elements of the PB web interface? Or might there be a template for what would be required to develop the features that are currently present in the PB web interface? Any advise or suggestions would be appreciated. Thanks
Disclaimer: I haven’t had an Apple machine for development since Objective-C was king, and have only a passing familiarity with Swift, and none at all with the playground. Still…
The Web UI uses both http and websockets protocols, a couple of different data encodings, plus decompression of the pattern binaries to access preview images if you want them. It’s a non-trivial undertaking. I’d do it in stages, probably starting with using the websocket interface to control the Pixelblaze.
You can get information on protocols from pixelblaze-client and the Firestorm source code. I’d also recommend looking at @nick_w’s async python library, because the async model is a better fit for Swift, and it also has some code dealing directly with binary pattern files.
@zranger1
Currently, I am able to use the websocket to control the PB. As I am in the early development stages, I am still working out how much of the PB web interface I need to recreate. Ultimately this project will be an app to introduce middle-schoolers to coding.
Thanks for the information. I appreciate the work that you did on the Python library.
There’s no tougher or more worthwhile task than getting kids to understand how fun and useful it is to know something about programming. Awesome! I look forward to seeing what you come up with!
Absolutely. Happy to share.
