when passing values into the rgb function my neopixel strip takes it in the order of brg
ie rgb(1,0,0) gives me a blue pixel.
hue is out of wack too…anyone run into this before?
Hey @Alsy!
Have you seen the RGB ordering setting on the settings page? That will probably fix your problem. Try the different settings until it matches the color order of R, G, B.
Thanks, that did the trick, I didn’t see that setting in my wanderings
