Two IKEA lamp hacks
The first hack is from a lamp called SKYMNINGEN. It is composed of white plastic wings on a central stem. I removed the main lamp (E27) and replaced it by two alu wound spirals with rgb strips. I wrapped them in a thin tissue (white felt) to get a better color diffusion. The low-q video shows only partially the nice glow reflecting from the white wings.
The second hack is from a wimsy lamp called KRUSNING, made of hand-wrapped paper sheets. Older hack videos show how to paint the sheets. I thought it a better idea to use rgb. The sheets are tightened within two plastic rings. I did not use that ring. Instead i attached a spiral with the rgb leds and the sheets are more or less hanging on it, with some space in between so the light can get thru.
Enjoy the videos.
Forgot to mention: both laps include approx. 80 pixels. If anyone feels attracted to design a special pattern for it, go ahead. … i will post the result.
