I wanted to play with the new palette support in v3.30, so I made my favorite palette, Viridis. I got the RGB values from a neat palette generator.
The idea is to generate 11 colors and have them evenly distributed between 0.0, 0.1, 0.3, ..., 0.9, 1.0. This will work with any palette generator that can generate 11 colors. If you have n colors then you can space them evenly with 1/(n-1) spacing.
# put these lines near the top, outside of function declarations
var viridis = [ 0.0, 68/255, 1/255, 84/255, 0.1, 72/255, 36/255, 117/255, 0.2, 65/255, 68/255, 135/255, 0.3, 53/255, 95/255, 141/255, 0.4, 42/255, 120/255, 142/255, 0.5, 33/255, 145/255, 140/255, 0.6, 34/255, 168/255, 132/255, 0.7, 68/255, 191/255, 112/255, 0.8, 122/255, 209/255, 81/255, 0.9, 189/255, 223/255, 38/255, 1.0, 253/255, 231/255, 37/255,]
var inferno = [ 0.0, 0/255, 0/255, 4/255, 0.1, 22/255, 11/255, 57/255, 0.2, 66/255, 10/255, 104/255, 0.3, 106/255, 23/255, 110/255, 0.4, 147/255, 38/255, 103/255, 0.5, 188/255, 55/255, 84/255, 0.6, 221/255, 81/255, 58/255, 0.7, 243/255, 120/255, 25/255, 0.8, 252/255, 165/255, 10/255, 0.9, 246/255, 215/255, 70/255, 1.0, 252/255, 255/255, 164/255, ]
var magma = [ 0.0, 0/255, 0/255, 4/25, 0.1, 20/255, 14/255, 54/255, 0.2, 59/255, 15/255, 112/255, 0.3, 100/255, 26/255, 128/255, 0.4, 140/255, 41/255, 129/255, 0.5, 183/255, 55/255, 121/255, 0.6, 222/255, 73/255, 104/255, 0.7, 247/255, 112/255, 92/255, 0.8, 254/255, 159/255, 109/255, 0.9, 254/255, 207/255, 146/255, 1.0, 252/255, 253/255, 191/255, ]
var plasma = [ 0.0, 13/255, 8/255, 135/255, 0.1, 65/255, 4/255, 157/255, 0.2, 106/255, 0/255, 168/255, 0.3, 143/255, 13/255, 164/255, 0.4, 177/255, 42/255, 144/255, 0.5, 204/255, 71/255, 120/255, 0.6, 225/255, 100/255, 98/255, 0.7, 242/255, 132/255, 75/255, 0.8, 252/255, 166/255, 54/255, 0.9, 252/255, 206/255, 37/255, 1.0, 240/255, 249/255, 33/255, ]
setPalette(viridis)
// setPalette(inferno)
// setPalette(magma)
// setPalette(plasma)
// in your render code replace hsv() with paint()
paint(v) # a bit too bright for me
paint(v, v) # darken dark areas
For example, here’s Sinpulse 1D/2D/3D using the viridis palette:
setPalette(viridis)
t1 = time(.05)*PI2
t2 = time(.09)*PI2
zoom = 1+ wave(time(.2))*3
t3 = time(.1)
render3D(index, index/pixelCount, 0, 0)
render3D(index, x, y, 0)
export var v, min, max
h = (1 + sin(x*zoom + t1) + cos(y*zoom + t2) + sin(z*zoom + t1 - t2))*.5
v = (h*h*h+1)/9
// figure out range of v so we can normalize above the +1 and /9 above
if(v < min) {min=v}
if(v > max) {max=v}
// hsv(h,1,v/2) // old
paint(v, v/2)
NB: You probably want to clamp the values to 0..1 so the values don’t wrap; or 0..n for some integer n if you want it to wrap n times. When converting an existing pattern I look at the min/max values and clamp manually.
