Hiya!
I have a pixelblaze 2, and I previously was connecting it to one of these guys. I easily did some tests where I could connect it just with a microusb power and run it at low brightness without issue.
I am working on a project that has the strips separated. I cut along the cut lines, wired a few of these cuts together, and connected. I am now getting a range of issues:
- Upon connecting, my voltage goes from 5V to 2.6V.
- I only ever get a few of the first leds lighting up, compared to most of the strip before
- Most functionality is intermittent/non functional.
I’m a little confused what could cause this change. Is it possible the soldering heated up the leds, causing greater current requirements? Is it dangerous to try to just keep pushing the power supply?
Any ideas for debugging it?
