Is there a way we can make a pattern or a collection of colors that will react to certain voltage inputs?
In other words converting my scooter into a giant voltmeter? Like at max battery, which is 67vdc it will be green, and as it progressively goes down, change the colors to red.
Absolutely! There is an analog input pin on Pixelblaze, and 5 more on the Sensor Board. The one on PB measures a range of 0 to 1v, while the sensor board does 0 to 3.3v. You can measure higher voltages by dropping or dividing them so they are in range.
