Here’s a quick demo of a new text renderer I’m working on. This is an early preview – it’s a long way from optimized, and needs to have more animation tooling added. I’m posting it now because I just got to a good place: the anti-aliased font rendering works, and the morphing just looks cool!
It’s set up for a 16x16 matrix. Should work on any 2D display though – you might have to use the sliders to adjust line width and size for best results on 8x8.
(Edit: 4pm, 1/4/2022 - updated code)
SDF Font Demo (WIP)
// SDF Font Demo with Morphing Characters
// (Work-in-Progress v2)
// 1/04/2022 ZRanger1
// UI control variables
export var objectSize = 0.85;
export var lineWidth = 0.085;
export var speed = 500;
// shape function selection - your message here!
//var shapeSdf = [_A,_B,_C,_D,_E,_F,_G,_H,_I,_J,_K,_L,_M,_N,_O,_P,_Q,_R,_S,_T,_U,_V,_W,_X,_Y,_Z];
var shapeSdf = [_P,_I,_X,_E,_L,_B,_L,_A,_Z,_E];
// animation control
var shape = 0;
var nextShape = 1;
var hue = 0;
var morphClock = 0;
var wait = 0;
var lerpPct = 0;
var t1, timebase,t2;
// move coordinate origin to center.
translate(-0.5,-0.5);
// comment/uncomment this line to flip charaters on x axis as necessary
// thanks @pixie, for the reminder!
scale(-1,1);
// UI
speed = 100+(v*1900);
export function sliderSize(v) {
objectSize = v;
export function sliderLineWidth(v){
lineWidth = 0.25 * v * v;
timebase = (timebase + delta/1000) % 1000;
t1 = timebase * 10;
t2 = time(0.04);
morphClock += delta
// morph to a new shape every other second...
if (morphClock > speed) {
if (!wait) {
shape = nextShape; // set to next shape
nextShape = (nextShape+1) % shapeSdf.length;
morphClock = 0;
wait = !wait;
lerpPct = morphClock / speed;
if (wait) {
d = shapeSdf[shape](x,y);
d = shapeSdf[shape](x,y) * (1-lerpPct) + shapeSdf[nextShape](x,y) * lerpPct;
v = (d <= lineWidth) ? 1-d/lineWidth : 0;
hsv((x+y+t2), 1, v)
// SDF function for line segment
function line(x,y,x1,y1,x2,y2) {
x1 *= objectSize; y1 *= objectSize;
x2 *= objectSize; y2 *= objectSize;
ax = x - x1; ay = y - y1;
bx = x2 - x1; by = y2 - y1;
h = clamp((ax * bx + ay * by)/(bx * bx + by * by),0,1);
return hypot(ax - bx * h,ay - by * h);
// original sdf text demo shader: https://www.shadertoy.com/view/lsXXRs
// font from https://dl.dropboxusercontent.com/u/14645664/files/glsl-text.txt , which no longer
// seems to exist.
// TODO -- need to rescale the segments to save calculation
function _A(px,py) {
var d = 1;
d=min(d,line(px,py,-0.28571,0.5,-0.28571,-0.42857));
d=min(d,line(px,py,-0.28571,-0.42857,0.28571,-0.42857));
d=min(d,line(px,py,0.28571,-0.42857,0.28571,0.07143));
d=min(d,line(px,py,0.28571,0.07143,-0.28571,0.07143));
d=min(d,line(px,py,-0.28571,0.07143,0.28571,0.07143));
d=min(d,line(px,py,0.28571,0.07143,0.28571,0.5));
return d;
function _B(px,py) {
var d = 1;
d=min(d,line(px,py,0.14286,0.07143,0.14286,-0.42857));
d=min(d,line(px,py,0.14286,-0.42857,-0.28571,-0.42857));
d=min(d,line(px,py,-0.28571,-0.42857,-0.28571,0.5));
d=min(d,line(px,py,-0.28571,0.5,0.28571,0.5));
d=min(d,line(px,py,0.28571,0.5,0.28571,0.07143));
return d;
function _C(px,py) {
var d = 1;
d=min(d,line(px,py,0.28571,-0.42857,-0.28571,-0.42857));
return d;
function _D(px,py) {
var d = 1;
d=min(d,line(px,py,-0.28571,0.5,0.14286,0.5));
d=min(d,line(px,py,0.14286,0.5,0.21429,0.42857));
d=min(d,line(px,py,0.21429,0.42857,0.28571,0.25));
d=min(d,line(px,py,0.28571,0.25,0.28571,-0.10714));
d=min(d,line(px,py,0.28571,-0.10714,0.21429,-0.35714));
d=min(d,line(px,py,0.21429,-0.35714,0.14286,-0.42857));
return d;
function _E(px,py) {
var d = 1;
d=min(d,line(px,py,-0.28571,-0.42857,-0.28571,0.07143));
d=min(d,line(px,py,-0.28571,0.07143,0,0.07143));
d=min(d,line(px,py,0,0.07143,-0.28571,0.07143));
d=min(d,line(px,py,-0.28571,0.07143,-0.28571,0.5));
return d;
function _F(px,py) {
var d = 1;
return d;
function _G(px,py) {
var d = 1;
d=min(d,line(px,py,0.28571,-0.28571,0.28571,-0.42857));
d=min(d,line(px,py,0.28571,0.07143,0.07143,0.07143));
return d;
function _H(px,py) {
var d = 1;
d=min(d,line(px,py,-0.28571,0.5,-0.28571,0.07143));
d=min(d,line(px,py,0.28571,0.07143,0.28571,-0.42857));
d=min(d,line(px,py,0.28571,-0.42857,0.28571,0.5));
return d;
function _I(px,py) {
var d = 1;
d=min(d,line(px,py,-0.21429,-0.42857,0.21429,-0.42857));
d=min(d,line(px,py,0.21429,-0.42857,0,-0.42857));
d=min(d,line(px,py,0,-0.42857,0,0.5));
d=min(d,line(px,py,0,0.5,-0.21429,0.5));
d=min(d,line(px,py,-0.21429,0.5,0.21429,0.5));
return d;
function _J(px,py) {
var d = 1;
d=min(d,line(px,py,-0.21429,0.5,0,0.5));
d=min(d,line(px,py,0,0.5,0.14286,0.35714));
d=min(d,line(px,py,0.14286,0.35714,0.14286,-0.42857));
d=min(d,line(px,py,0.14286,-0.42857,-0.21429,-0.42857));
return d;
function _K(px,py) {
var d = 1;
d=min(d,line(px,py,-0.28571,0.07143,-0.07143,0.07143));
d=min(d,line(px,py,-0.07143,0.07143,0.28571,-0.42857));
d=min(d,line(px,py,0.28571,-0.42857,-0.07143,0.07143));
d=min(d,line(px,py,-0.07143,0.07143,0.28571,0.5));
return d;
function _L(px,py) {
var d = 1;
return d;
function _M(px,py) {
var d = 1;
d=min(d,line(px,py,-0.28571,-0.42857,0,-0.07143));
d=min(d,line(px,py,0,-0.07143,0.28571,-0.42857));
return d;
function _N(px,py) {
var d = 1;
d=min(d,line(px,py,-0.28571,-0.42857,0.28571,0.5));
d=min(d,line(px,py,0.28571,0.5,0.28571,-0.42857));
return d;
function _O(px,py) {
var d = 1;
return d;
function _P(px,py) {
var d = 1;
return d;
function _Q(px,py) {
var d = 1;
d=min(d,line(px,py,0.28571,0.5,0.07143,0.28571));
return d;
function _R(px,py) {
var d = 1;
d=min(d,line(px,py,-0.28571,0.07143,0.07143,0.07143));
d=min(d,line(px,py,0.07143,0.07143,0.28571,0.5));
return d;
function _S(px,py) {
var d = 1;
d=min(d,line(px,py,0.28571,0.5,-0.28571,0.5));
return d;
function _T(px,py) {
var d = 1;
d=min(d,line(px,py,0,0.5,0,-0.42857));
d=min(d,line(px,py,0,-0.42857,-0.28571,-0.42857));
return d;
function _U(px,py) {
var d = 1;
return d;
function _V(px,py) {
var d = 1;
d=min(d,line(px,py,-0.28571,-0.42857,0,0.5));
d=min(d,line(px,py,0,0.5,0.28571,-0.42857));
return d;
function _W(px,py) {
var d = 1;
d=min(d,line(px,py,-0.28571,0.5,0,0.21429));
d=min(d,line(px,py,0,0.21429,0.28571,0.5));
return d;
function _X(px,py) {
var d = 1;
d=min(d,line(px,py,0.28571,0.5,0,0.03571));
d=min(d,line(px,py,0,0.03571,0.28571,-0.42857));
d=min(d,line(px,py,0.28571,-0.42857,-0.28571,0.5));
return d;
function _Y(px,py) {
var d = 1;
d=min(d,line(px,py,-0.28571,-0.42857,0,0.07143));
d=min(d,line(px,py,0,0.07143,0,0.5));
d=min(d,line(px,py,0,0.5,0,0.07143));
d=min(d,line(px,py,0,0.07143,0.28571,-0.42857));
return d;
function _Z(px,py) {
var d = 1;
d=min(d,line(px,py,0.28571,-0.42857,0,0.07143));
d=min(d,line(px,py,0,0.07143,-0.21429,0.07143));
d=min(d,line(px,py,-0.21429,0.07143,0.21429,0.07143));
d=min(d,line(px,py,0.21429,0.07143,0,0.07143));
d=min(d,line(px,py,0,0.07143,-0.28571,0.5));
return d;
