hey all
I made some cases for myself, thought they might be useful to others. Feel free to remix these if you like – I’m including STEP files (links below), so you should be able to edit them.
No guarantees, no warrantees, no promises ![]()
I made this case for a new build for Twisty Maurice – 2 PBs V3, and 8 Output Expanders
These are very purpose built cases – I wanted to be able to plug in all the boards to headers w/ header pins. The PB case keeps the antenna in the clear, and gives access to the button. The tops are printed in clear(ish) PETG so the ready lights could be seen. M2 screws secure the case tops, and for the PBs.
The OEs don’t have screw holes – so the case tops are designed to hold them in a snug fit.
Both of these headerpin cases put the ‘case’ part in the lid – makes for simpler 3d printing.
NOTE: they are about 1mm short on purpose – I used VHB tape to tack them onto the breadboards. They sit firmly and securely with the tape, w/o it they wobble.
Pixelbaze Riser Case:
PixelBlaze_HeaderPinOffsetCaseV2.step (110.3 KB)
Output Expander Riser Case:
OutputExpander_HeaderPinOffsetCase_V2.step (105.6 KB)
I’m also posting another case design – but new post, as the is one is already long ![]()
tagging @wizard
cheers
-andy
