Continuing the discussion from Blinkfade in Cube Frame:
Porting the .ino code is pretty simple:
it’s a 5 second of doing nothing, then it lights up each pixel, in order, for X milliseconds.
// 3d video processing v0.1 alpha by ScruffyNerf
export var seconds, pixel
// This part is not in millis, but seconds to avoid 16bit overflows
var initial = 5;
// initial pause in seconds
// How many Seconds each pixel is shown for?
// you will need to multiply by 1000 to convert to milliseconds
var speed = .2;
export var loopTime = initial + (pixelCount * speed);
// In millis, this would be 1000 times larger
// and go past the 32767 limit for even 200 pixels...
seconds += delta/1000
if (seconds > loopTime){
seconds = 0
pixel = floor(( seconds - initial ) / speed )
if ( (seconds > initial) && (pixel == index) ) {
rgb(1,1,1)
else {
rgb(0,0,0)
I’ve stuffed a bunch of fairy lights into a big mason jar. No way could I easily build a map for this, it’s just a bunch of wires. More results and some video later.
