HD-108 compatibility
Sure, I’ll order one. Let’s take this fresh blinkiness 2D! :woman_astronaut:
OooooooOOOOOOOooooooo! :face_holding_back_tears: YESPLEEZ! Thank you so much. That’s almost unbelievable turnaround.
Yeah, they’ve been a hoot. I have two spools of 30/m IP68 for outside, and two spools of 60/m in the crown molding of a pitch black home theater. Apart from a variety of hand-coded demos, I’ve pretty much just used them for lights-on and lights-off. (While planning ambitious transition animations and other triggered effects.) The kid would now like to take charge and run it much further, much quicker. Cue that happily obsolete feeling.
The theater strips are powered and controlled from right above the projector lens passthrough, on the rear wall. So, from the center of a horseshoe configuration 12’ : 12’ : 12’, with 10AWG feeding the front and back of each 300pc strip.
Electronics-wise, how would you suggest I plan to transition from my Raspberry Pi 4 to our new V3, with or without our new output expander? (The exterior 150pc runs are easy: each will just be driven by its own Pico instead of a Pi Zero. I’d pulled one strip inside for this Thing Dev work.) Should I put the theater on a pair of Picos and try to drive it from Firestorm?
Once again: thank you for bumping this special request forward so quickly! The girl and I are both just tickled about it. High fives all around. :crazy_face:
I have recently soldered up my first PCBs with some HD108 LEDs. Home reflow was a success!
Now I have to get it working with PB or with this FastLED fork on a Teensy 4.0.
Let me know if you want a build to play with.
Do you mean a PB build with the Apa102Adapter modified to support HD108? If so, then yes please! I have a picoblaze running V3.30
Hello, @wizard I am trying to control the HD108s LED strip and it is lighting up as you mentioned but in very few occasions which I couldn’t understand what causes it. I couldn’t manage to control it. I am using H807S controller. Please let me know if you recommend anything or if you have figured out how to work with this strips.
Hi @grymstone,
Sorry I don’t know anything about that controller. This forum is about the Pixelblaze LED controller. If you give the Pixelblaze a try I’m sure it should work, and can help you out if you have problems.
Hi! I’ve just ordered a Pixelblaze, thanks for creating such an amazing product and community! I have a LED strip with HD108 chip and have been following the support for it for a while now.
Has there been an update or new experiences since this last message in 2023? Or should I test it out with the merged code from 2022 in this thread?
Would love to be able to utilize the 16-bit combined with the 5-bit brightness. :slight_smile:
Thanks in advance!
I added support for NS108 in v3.47
I hope that works for HS108 too, or there’s yet another protocol out there!
Great! Gonna test it out once I’ve received it. Thanks a lot for your quick response.
Just wanted to confirm that the HD-108’s work perfect with the newest PB update!
Great to hear, thanks for confirming!
Hi, here I am again! Received both my Pixelblaze and HD108, and both are working great. The only thing I cannot use, is the global brightness control. Does the pixelblaze use this internally and is it connected to the brightness slider in the GUI? Is there a way to use/program this in code as well? I would love to be able to program even smoother fades that way. Thanks for the advice!
