I recently purchased some hd-108 16-bit strips. When connecting to pixel blaze, I get some weird stuff happening with the lights. Has anybody had any luck connecting hd108 strips to pb?
The company of course is blaming it on the control arm using but I’m pretty sure it’s the strip when checking continuity the power and ground wires are reading . 1 ohms and the data and clock wires are reading some crazy number like 12 ohms which leads me to believe there’s Breaks in the copper traces. Thank you
Twilight
These have a completely different protocol, and aren’t backward compatible.
I do want to support these, the range is amazing.
Well I recant my statement. Hard to feel like you’re not getting ripped off sometimes especially when the company gives you the run around and takes over a month to get your order. Can anybody Point me in the direction of a pre-assembled controller thats compatible with HD 108 16 bit strips.
Thank you,
You guys are Dope!
Twilight
I’ve been keeping an eye on the HD108 LEDs and they certainly look promising, though I haven’t ordered any yet. As far as I can tell, software support is pretty thin on the ground for them so far. Until there’s PixelBlaze support for them, I imagine this library will be your best bet in conjunction with an ESP32. There’s more info on this libaray and HD108 in general here and also some example code for how to control them directly with SPI here.
Whatever you end up doing I’d be interested to hear how you get on. Also, any chance you could share where you ordered the strips from?
Related, how do you feel about the WS2816s?
I have some HS108s and WS2816s, a few micro 8x8 panels of 2020 WS2816s, but backburnered support with all the other features being requested.
WS2816s can sort of be hacked into working by packing RRG+GBB across 2 pixels since they use the same wire protocol, just twice as many bits.
Interesting, I hadn’t seen those before. It took me a while to find an English data sheet for them. They sound pretty good on paper at least, though somewhat less so based on the earlier thread where you were discussing them. It doesn’t look like there’s an obvious supplier of WS2816 strips unfortunately and I haven’t yet tried any projects requiring SMD or custom PCBs, so personally I’m unlikely to try them anytime soon. Maybe other people here feel differently?
Ah, I recant these statements:
I had some bit/math error with the hack I was using. These are quite good.
I would add that at some of the very low levels the PWM/refresh rate is more noticeable. I suspect they are using bit dithering for much of the extra range. I would suspect hs108s to do this as well. I haven’t put these to a photodiode and scoped it yet.
16 bit PWM requires 65k cycles per refresh, a refresh of 10k would take a clock of 65k*10k = 650MHz, which im sure they aren’t doing. If they did 8 bits at 10khz on a 2.56MHz clock, every bit dithered on top of that would be at half the refresh, down to 39hz for the LSB, which would be quite visible if it wasn’t so dim. Again they could double that by doubling the clock and having more bits in the primary PWM.
Awesome led tricks like this explained in this video
Ill share the website, but it doesn’t really come with a recommendation. https://www.addressableledstrip.com
Newstar Led. You cant order directly on the website you have to email them for a quote and then pay through PayPal. I have not been able to get the strips to work properly but, I can verify that the whole strip is lighting up. Fast Led has a hd108 branch available and thats what I’m going to try next.
Twilight
Is there anything I can do to help boost NS108s from the backlog? I’ve been driving mine from custom code, but my daughter just expressed an interest in talking to them with Pixelblaze.
I’m thinking I could fork the Apa102Adapter header and tweak it to upscale 8-bit source data into the new NS108 protocol.
Assuming I can demonstrate that working through strandtest, would that help you land basic 8-bit support into Pixelblaze soonish?
Huge appreciation to you: you’ve got a remarkable thing going here. I’m eager to indulge my daughter’s interest before it fades, so let me know anything I can do to help. Programming graybeard, electronics noob. Put me to work. ![]()
Thanks!
That would certainly help! I would make a new one (either new repo or a new object/driver).
My plan is to convert all the PB internals so that the color is kept in 16 bits (for all kinds of other good things) which is the bulk of the work, then downscaled if needed. I’ll treat apa102/sk9822 as a completely different LED type than NS108/HD108.
Perfect! Sounds like we’re very much on the same page. 16-bit is a huge ask, but just doubling 8-bit on output should cover most of the need for now. Maybe adding experimental clock rates up to 40 MHz.
I’ll need to run by Microcenter once it’s open, to get my hands on an ESP8266 dev board. I’ve got some Seeeduino Xiaos and a few other collected oddities around, but it’s been a while since I’ve gone smaller than Raspberry Pi.
While I wait to level up on hardware, I’ll post my early once-over of the C++ into the GitHub issue.
BTW it looks like Adafruit’s APA102 table of macros is misconstructed for RGB sequences that aren’t in common use anyway. ![]()
Thanks!
Can you elaborate? True, I haven’t seen/tested many of those combinations, but the bits look OK to me.
Well, then I’m probably in for a rude awakening about either endianness or word size for this build chain and MCU.
Far be it from me to challenge both you and Adafruit!
But just on the face of it: neither the LSB nor the MSB consistently tracks any specific component? That’s what jumped out. On closer analysis, it seems to me that RGB, RBG, GRB, BGR are correct while GBR and BRG are swapped. That’d reflect a trivial mis-edit.
I just brought home a SparkFun Thing and Thing Plus; hopefully I’m not far from learning how far off I was at 4AM. ![]()
Maybe we are looking at it differently.
This assumes a source in RGB, and defines the output index for a given element. In other words an answer to the question “given a value for red, where in the output does it need to be?”
buf.b[rOffset] = rgbv.b[0]; //push red to dest
buf.b[gOffset] = rgbv.b[1]; //green
buf.b[bOffset] = rgbv.b[2]; //blue
write32(buf.frame);
You code works in the other direction, the indexes define which index into RGB to pull from for a given output byte.
output.s = {1, gain, gain, gain,
(pixel.b[componentOffset[0]] * 0x101), //pull first byte from src
(pixel.b[componentOffset[1]] * 0x101), //pull second byte from src
(pixel.b[componentOffset[2]] * 0x101), //pull third byte from src
Your color coding makes it clear!
Much appreciated.
I imagine I’d have gotten there once I see wired runtime results, but I wasn’t resolving it from staring alone. Wild that the forward and reverse mappings are equivalent for 2/3 of the set…
Yup, these make me happy. FWIW: I had also initially guessed wrong on endianness. Big day! ![]()
Let me know if there’s anything more I can do to facilitate readying it for Pixelblaze. Of course I offer it to you Ben to use for any purpose, and consent to your licensing it MIT and/or in any other form you choose, presumably consistent with the other drivers.
I’ve taken another run at a new write64, and that’s performing great (on ESP8266 so far). Eliding half of the spinlocks, and presumably leaving far more parallelism for pixel calculations.
I’m trying to hold back on posting another full source file as comments in a GitHub issue.
Maybe go ahead and add a driver project in the style that you want. Or I could DM it to you?
Added later: GISTS! Why didn’t I think about gists.
I purchased a Digi quad and was able to install the fast Led library and several of the pattern examples work fine with some of my other strips, ws2811 and ws2815. But I could not get the the HD 108 Library written by nlag to work kept getting errors when I went to upload to the esp32. My last option was to order a garbage controller that new star and super lighting LED verified was compatible with HD 108 strips. I’ll report back once I get it next week.
Twilight
Building some HD108 versions of my HDR 8x8 panel so I have something to test with. Any interest? I can make a few extra.
Preliminary testing has been interesting!
Merged code here, with a few changes:
Right now I’m just testing with a hack to swap out apa102 with the NS108 driver, using the same 8 + 3 bit color. Let me know if you want a build to play with.
These will update at 40MHz on Pixelblaze, which is quite impressive. It’s way overkill, even a trivial pattern like the example rainbow don’t benefit beyond 8MHz. I think 20MHz might be useful for patterns entirely from a buffer, but marginally so.
In addition to a crazy high data rate, they latch and display very quickly. I was able to see at least 5000FPS (only 18 pixels, but still).
The sad news is that the LEDs I used are either bad or had absorbed a lot of moisture even with a sealed pack + baking, and out of 4 8x8 panels every panel is bad, with 1/3rd to 2/3rds usable.
I’m also seeing some per-pixel variations that might be caused by damage. Some weird things / glitches happen for some of the LEDs in the first 10 or so levels.
The brightness around the lowest range is really good for most things and on par with APA102 even without the extra 5 brightness bits. With the extra bits, it would be hard to see them fade to blank unless you were in pitch black and looking right at them.
The extra bits aren’t directly compatible with SK9822 / APA102. Looks like they have a range of 3-34 out of 34 instead of 0-31 out of 31.
