I have a rectangular sign that im surrounding with a strip of about 380 pixels as a marquis effect. The proportions of the sign are 4 to 1, which means that short sides are 38 pixels ‘tall’ and 152 pixels ‘wide’. What is the best way to set up a map for this?
Hi,
Sounds like a fun project! Try using something like this line example with 4 sides.
Start with where the strip signal starts, and draw a line. So for example, if it starts in the top left, and proceeds clockwise:
function (pixelCount) {
function line(x, y, dx, dy, count) {
var line = [];
for (var i = 0; i < count; i++) {
line.push([x + dx * i, y + dy * i]);
return line;
var map = [];
// start at 0,0, move 1,0 for each pixel, 152 pixels
map = map.concat(line(0,0, 1, 0, 152))
//then moving down, assuming 1 pixel from above counts toward the 38 tall
// start at 152,1, move 0,1 for each pixel, 36 pixels
map = map.concat(line(152,1, 0, 1, 36))
//then from the bottom right to bottom left
map = map.concat(line(152, 37, -1, 0, 152))
//and back up
map = map.concat(line(0, 36, 0, -1, 36))
return map;
