Pico Not Detecting 6-Axis Sensor
Hello!
I was just getting into using the 6-axis sensor on the Pico and created my first pattern with it. It was working perfectly fine then I decided to do a firmware update on it from v3.48 to v3.67. I used the “v3.67.pico32.stfu” file to upgrade it manually. The update went through, but now my 6-axis sensor is not showing up and my var export SixAxis no longer works.
Before my firmware update it had “6-Axis” displayed next to the expansion field, now it does not on either version:
I tried to revert to version v3.47 but it still is not detecting it.
Any ideas?
Thanks!
You’ll want to update to v3.69. There was a bug that creeped in!
Got it working on v3.69, thanks!
3 posts were split to a new topic: How to use the Pico’s six axis sensor
