Quick preview of the next PixelTeleporter update.
I wanted to see if the Fibonacci layout boards were really as cool as people were saying, so I wrote this example sketch. The gif shows the standard 1D Block Reflections pattern. It’s a little over-the-top because it’s using the new experimental blur/persistence renderer, but the spiral layout is indeed super cool!
Source code for the example below so you can check it out early if you like. Set the background to white, run the pattern without a Pixelblaze connected, and you can use it to print the spiral out as a drilling guide if you want to make one of these on your own.
// Pixel Teleporter Fermat Spiral (Fibonacci256) example
// 10/21/2020 JEM (ZRanger1)
// Creates a fermat spiral of 256 pixels. Use an angle of 137.5 to create a "normal"
// fibonacci pattern, other angles create other interesting spirals and patterns.
import pixelTeleporter.library.*;
import java.util.*;
// constants
final int numRows=16;
final int numCols=32;
// global variables
PixelTeleporter pt;
LinkedList<ScreenLED> panel; // list of LEDs in our matrix w/position and color info
//PShader blur;
LinkedList<ScreenLED> buildFermatSpiral(int pixelCount, float angle) {
float x,y,r,theta;
float pixSize;
float originX = 0;
float originY = 0;
ScreenLED led;
// set pixel spacing to something that looks reasonable
pixSize = 1.4 * pt.getElementSize();
panel = new LinkedList<ScreenLED>();
// create spiral, pixel 0 at center.
for(int i = 0; i < pixelCount; i++) {
r = pixSize * sqrt(i);
theta = i * angle;
y = originY + (-1 * r * sin(theta));
x = originX + (r * cos(theta));
led = pt.ScreenLEDFactory(x,y);
led.setIndex(i);
panel.add(led);
return panel;
void setup() {
size(1000,1000,P3D); // Set up the stage
pt = new PixelTeleporter(this,"127.0.0.1");
pt.setElementSize(18);
// Optional - load single pass blur shader
// blur = loadShader("blur.glsl");
panel = buildFermatSpiral(256,radians(137.5));
// add very slow rotation to enhance trippyness. Spacebar toggles
// rotation on/off, mouse wheel zooms, 'r' resets to original orientation.
pt.setRotation(0,0,0);
pt.setRotationRate(0, 0,PI / 8000);
pt.start();
void draw() {
background(15);
// draw LED matrix
pt.render3D(panel);
// Optional - Apply blur shader.
// filter(blur);
