I am confused about how SK6812 RGBW (4 LEDs version) is supported by Pixelblaze.
According to the spec SK6812_RGBW_REV01.pdf (1.0 MB) this LED required 32-bits of
data (this makes perfect sense) but Pixelblaze send only 24 bits.
I found next explanation on how Pixelblaze is dealing with SK6812 RGBW LEDs:
According to the above explanation it looks like there is no way to light up all 4 LEDs.
@wizard could you please briefly explain what is a real story?
I am looking for the simple RGBW Strip replacement but I need to max brightness.
Most of the time I will need Warm White (2700K) bright color for the entire strip.
Occasionally status for the appliances will be indicated with different colors
in areas right above the correspondent appliance.
